Here's an update.
It's not
completely dead, but there's definitely a dead component inside the RF module.
I have an ancient "signal tracer", effectively a high-impedance audio amplifier, which can be used to probe circuitry to see where a signal exists and where it doesn't.
Here's a
block diagram (and pin-out) for the RF Module in the factory tuner.
Note that pin-1 is nearest the Antenna Jack.
The FM audio is
working at the
Level pin, but
not working at the
RDS MPX pin, nor at the
FM MPX pin. This indicates a faulty
FM Demod stage inside the RF Module.
Next I'll pop off the cover and probe inside the RF Module, to see if the
FM Demod is accessible and repairable.
-m
