Done, here is the Wiki page that I created to put up the images. There are three sizes, sized so you can use them with the /proc/empeg_screen.png file easily. The large size is very big, the screen image would have to be scaled to 640x160 to be used with it. It's from the full-size render that Rob posted about and Bitt found above. The medium size is good for a double-sized screen png, I've also included a .zip file with an exploded view from the wiki page. I integrated these into Mark's modification to the web interface (screenshot below). I also included the GIMP sources in xcf and a small size. These renders look MUCH better than the one we've been using from CG99's web interface. Tony, you may want to look at these for EmpegFace.
Mark Cushman
