I'm confused. Why would the files have drm. They are not protected. If they were drm, you would not be able to change or do anything with them.
So even if you reencode to the same bit rate and same wma file, does any kind of reencoding degrade the music file? So it's no difference???? frown as if you change it to mp3 like nicky did. That sucks. I always thought reencoding to the same bit rate and same file made no difference since it has the same file property.
