Errors trying to install Emplode 1.03b as a normal user on a W2K box with a Linux/Samba domain controller.
1 Double click the file "emplode-v1.03-beta3.exe"
2 Window "Emplode - Installshield wizard" opens.
3 Immediately after, a small dialog box (no icon) with the subject line "C:\DOCUME~1\NICK~1~HHG\LOCALS~1\Temp\pft23~tmp\pftw1.pkg" and message body "The system cannot find the path specified" appears.
4 Click OK on the above window and another small dialog box pops up subject "Error Executing the Specified Program", body "SETUP.EXE /SMS"
5 Click OK on the above window and another small dialog box pops up subject "emplode", body "Unable to execute the specified command line".
6 Setup quits and I'm back where I started.
The problem seems to be with point 3 - the full directory spec should be: "C:\Documents and Settings\nick.HHGTTG\Local Settings\Temp" and it's the "nick.hhgttg" bit which seems to be causing the confusion.
Anybody got any ideas?
I'll try logging in as local admin on the machine and see what happens then.
Nicholas.
18GB red s/n 080000299, original pos'n 8724. Reproduction of this post is not permitted.
