You can't link to the DSE website directly.
Ah, so you can't, my bad
An M205 fuse is 20mm long x 5mm in diameter. Massive compared to what you are replacing. That said, if rated appropriately it would work but it would be a very very ugly fix.
I realise it isn't an optimal solution, but I thought if I ran a couple of wires off it I could place an M205 Fuse in a fuse holder somewhere else inside the case such that if it blew again it would be a simpler replacement than SMD soldering.
That said though, I'll give Farnell a try first. I guess it's taken around ten years to blow, and I can probably afford to replace it every ten years.
Also thanks for the offer Stu, I'll try Farnell first since shipping should be cheaper and faster hopefully.
