Hi,
Ya got no tags, dude.
Looks like you may have the same problem I had recently.
An easy identifier, go to /empeg/var and if you don't have a database file and a playlist file, the player needs to rebuild them. When you are at that directory, type ls -la to see the directory files.
Go into the current thread "builder_bigdisk_v3 now available" under the Forum List General section. Start with message #340780 and specifically #340815 where Roger told me to how to have the player rebuild the database and playlist files in /empeg/var. A good example of this is shown in message #340932. It shows the BEFORE with the files missing and the AFTER with the files there after the rebuild. Make sure you do the "rom" as Roger mentions at the end of his fix.
