Yes it is....
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard diskStarting player
Timezone: EST
Hijack: intercepting config.ini
Check out
The Tremors the best hillbilly rock n roll you ever set your corn fuel soaked ears to.
MK2a 250gig #030102295
