I am with BT for my FTTC so options are really limited, I can't change anything, not even supposed to use the Draytek! But the HomeHub supplied really does suck big time. Underneath it's good but the firmware is terrible if you want to change even the simplest thing.
Ah. If you've got BT Infinity then you are supposed to use their VDSL modem and their HomeHub. If its another ISP then you're just made to use the VDSL modem and you supply the router.
I've no idea how well BT Infinity supports IPv6 and you're unlikely to have a 1500 MTU/MRU which may need some careful tweaking of VPN and connection parameters.
I guess you're on the Option 2 package if you've got 10Mbps upstream?
