Been searching for it with no luck my words are too general to find it if it already exists.
Can you swap drives among two different players that already have music on them?
I have two players (1 is a MkII, 1 is MkIIa) and one of the drives died in the MkII so I took a drive from the MkIIa and installed it in the MkII (it already had a drive in it). Emplode shows only shows the storage cap. of the original drive but I can hear the replacement drive spin up and will boot, the player boots into the playlist screen but says -none-, when I try to sync with Emplode using only the swapped drive installedthe player quickly restarts at the point Emplode is performing the 'check media' stage, player is finished rebooting into playlist screen then Emplode crashes. If I hook the players original drive up by itself Emplode works normally.
I've tried swapping master/slave positions tried each drive separately as both master and slave.
Edited by Snowshoe (25/01/2012 20:28)
