Oh, one other thing:
I bought the shutter release, which connects via the mini-USB on the camera, installed the firmware, and it works fine.
Based on that description, we can't even be certain that the shutter release device is even a true USB device at all. It might just be something proprietary that *happens* to use the USB jack on the camera.
Yeah, a softer extension cable might be your better bet. Or a longer one, with the extension making a loop on the ground between you and the camera, to remove all vibration transfer.
Finally, you might find that, even after you do all of the above, that your problems aren't due to vibration from the shutter release cable. Maybe it's vibration from somewhere else, maybe even internal to the camera such as the shutter itself.
http://chdk.wikia.com/wiki/USB_Remote
Seems you're right. They're just switching in USB power to the USB port which the firmware detects as a "keypress".
All you really need is some sort of bluetooth IO module with corresponding pc/phone side app and the io module pins connected to the USB socket correctly.
