In that case, would two pieces of wire connected to a mini-USB connector on the camera end, the other end connected through a momentary contact switch to a 9-volt battery, do the job?
In the link he quoted above, a wiring diagram is given for something very similar to that. But it uses a CR2032 button battery, not a 9-volt. You wouldn't want to hook up a 9-volt to a USB plug.
