Surely the low hassle solution is just to turn the PC off at the wall when it is "off".
That would be true... except that reaching the power source at the wall is anything but low hassle. (...)
A lot (most?) PSU's also have a small switch on the back which completely turns off the power. If that's also present on your PC, and you can reach it, that might also be an option.
