It's just like old times on the empeg board. I post a question about something I've been dealing with for a day or more, and I immediately make progress on it.
I finally realized that I should test it out by opening a command prompt and running the batch file manually. First it complained about my syntax, so I took out everything after "PASSWORD." Then it technically worked, but it informed me that the path wasn't found. I figured that might be a problem, so I added "photos" to the end of "net use Z: \\192.168.1.21\" and that worked.
So I get that the net use command wants "devicename\sharename" but is there any way to leave the share name blank? I'd hoped to be able to map a drive that could show all the shared folders for that device...
