Stupid question:
The extender board does not require an additional power supply, correct? It should work as expected with the parts supplied in the box and power applied to the player only, correct?
There was a note on the instructions about how one could apply additional power to the extender board if you were going for longer cable runs. But the additional power isn't needed if you're only using the ribbon cable supplied in the box, correct?
Thanks!
