In Excel 2011 Mac, you have to create your own shortcut.
Go to tools>customize keyboard. select edit under categories, you'll find "paste values" on the right (a couple items under paste special). Just press a shortcut sequence (command+d for example) and add that as a new shortcut.
my life has improved so much since.
This was the right answer! I remapped Shift+Cmd+V to Paste Values. Thanks so much Tony. Sometimes it's the little annoyances that can make the day so much more frustrating. I tip my hat to you sir!
