"Upon the first startup into tuner, the sound was WAY off. I found that after altering just one setting in the EQ, the sound was changed to how it should have been. I can't get this to repeat so it really isn't much of an issue unless someone doesn't know about it. "
I have noticed this behavior too, but I don't have to have the tuner on at all for this to happen. It happens quite frequently when I get into the car. Something is definitely wrong. When I installed the tuner, I put in a new wiring loom, so I don't think its a loose wire. I hope its a software problem that will be fixed in 2.0.
Sean
