I'm able to use my Empeg Logo Editor combined with UltraEdit to create an image that works for the Tux visuals. Eventually I will work this into the logoeditor code as an actual "Save As" option, but for now here is how to do it:
- Create the desired image as the "home" image in LogoEditor. If it's in the "car" image, use the swap home/car feature to get it in the home slot.
- Save it as a BIN file in LogoEditor.
- Open that file in UltraEdit, in Hex mode.
- File size, as displayed in bottom-right corner, should be exactly 4100.
- Select the first four bytes of the file (my first four bytes are the letters "empg" for example).
- Ctrl-C to copy those bytes to the clipboard.
- Ctrl-V twice to paste the bytes into place, once atop and once inserted.
- File size, as displayed in bottom-right corner, should be exactly 4104.
- Place cursor at the beginning of the file in the binary half of the screen.
- Atop the eight pasted bytes ("65 6d 70 67 65 6d 70 67" in my case) type the following eight bytes instead: 80 00 00 00 20 00 00 00.
- File size should still be exactly 4104.
- Scroll to the hex address 00000808h and place your cursor on that byte.
- Press Ctrl-Shift-End to select all bytes from there to the end of the file.
- Press Ctrl-X to cut all of those bytes.
- File size, as displayed in bottom-right corner, should be exactly 2056.
- File, Save As, "logo.raw". Make sure file name is all lower case.
- Connect to the empeg with Hypterterminal. I assume you know all about this one by now, if not search on the FAQ for "hypterterminal".
- In hyperterminal, press q <enter> to get out of the player. Should drop you to the shell prompt (must have developer installed).
- cd empeg/lib/visuals
- You should be in the empeg/lib/visuals directory.
- rw
- rm logo.raw
- rz
- Should say "waiting to receive". In hyperterminal, select Transfer/Send File and go get the logo.raw you saved. Send it.
- Back at the player's shell prompt, ignore any extra garbage on the line.
- chmod 644 logo.raw
- ro
- exit
Enjoy your new logo! Right now I've got Yoda's eyes throbbing at me...
NOTE: This only works for Tubular, TuxMuch, and TuxTooMuch. It does not work for the "Logo" visual.
