Actually, it is even able to switch between tuner/pcm modes also so that if you output audio while you're in tuner mode, it'll fade the tuner volume down, switch to pcm, output the pcm, switch back to tuner and fade the volume up.
That is sweet. Me want. Me want badly. :)
