What about the jumper on the slave drive? Maybe it's loose. Even if it looks like it's attached OK, perhaps it ratlles a little and the pins need to be bent to make it connect firmly. Also, you might want to check the IDE connection on the motherboard. Finally, as stated in the FAQ, it's possible the cable itself might be a bad one.
