It shouldn't have taken that long, Laura, even for USB (ethernet is only a tiny bit faster than USB). Sure you weren't using the serial port?
Did you get any error messages?
If you really were using USB, perhaps there's something wrong with the USB setup on your PC. Maybe a motherboard BIOS upgrade is needed, or a device driver for the USB controller needs to be installed?
