Hi Till.
First: Congratulations, you got more of a responce from teleAtlas than I got.
You are right that GMF data discs seem to be easily available. BUT if I read the (german) discription of those maps that I found at
http://www.poly-electronic.ch/cd-karten.htm correctly, those aren't intended for real navigation tasks in the way we want it, but rather those are for moving map applications (read: rasterized maps, not vector based). Also, the map format doesn't seem to be well documented.
G
DF maps would be different though, they are really well documented. Rather hard (or expensive) to get, though.
cu,
sven (just started working his way through the GDF documentation)
