Okay, Hijack v182 is out.
This version just has some internal cleanups, but also:
  • "Home/Work Location" menu only appears if actually used in config.ini
  • new config.ini option to prevent Emplode/Emptool/etc.. from connecting to the player:
    [hijack]
    ;@WORK disable_emplode=1
    Note that if you fsck up and leave out the ";@WORK" prefix, then you'll have to either FTP or revert to an older kernel to fix config.ini afterwards..
