You're absolutely right. I've just looked in the code of displayserver and this is the only place where I use a hostname in the URLs. Mediaplayer over proxy should work I think, as it uses IE's proxy settings. I still think it's rather strange that winamp soesn't support HTTP-proxy's
CORRECTION : winamp does support HTTP-proxy, so theoretically it should work as described earlier...
Edited by fvgestel (06/02/2002 07:59)
Frank van Gestel
