First bug: I noticed this the day I got the player, but I forgot to bring it up until now. The visualization that shows the bouncy artist:title text in really big letters (there are three variations on this vis)... sometimes it puts a piece of garbage graphic in front of the artist name.
Some notes about when it happens:
1) The graphic garbage appears to be a random piece of the frame buffer that holds the rendered lettering.
2) When it happens, it doesn't happen right away. It sometimes takes a few scrolls before it appears.
3) When it happens, I can induce the bug by switching the vis between fullscreen and info display back and forth a few times.
4) It only happens on strings of a certain length. For instance, I was just looking at it, and the string "Steve Morse: Ghostwind" produced the bug, but the string "Sting: Fields of Gold" did not produce the bug. Perhaps it's related to the fact that it's a proportional font being used to render the letters.
Second bug: When you adjust the volume with the remote control, the track up/down buttons on the remote will continue to adjust the volume after the slider has appeared on the screen.
I understand that the track up/down buttons are the same as the volume buttons when you're using the front panel, but they should really be independent when you're using the remote. Is there any way to make the behavior different when using the remote?
The biggest problem is that this bug causes a safety hazard. Let's say I want to alter the volume and immediately change the track. For instance, my favorite song starts up, but it's too quiet. So I grab the remote, bump up the volume and then I want to hit the track-down button to restart the song. Well, I have to wait until that little slider disappears before I can hit the track-down button. Which means I'm looking at the display, not the road, during that period.
