Running 2.00b11 emplode and player. No HiJack before this happened.
I get this weird little bug from time to time....
If I drag a folder into emplode when there is already a playlist by the same name, the playlists are merged. As in: Dragging a folder called "Remixes" into my "Rabbit in the Moon" playlist that ALREADY has a sub-playlist called "Remixes" simply combines the two "Remixes" playlists and adds the newly added tracks to the end. I've always considered this a bug, but I've learned to deal with it and I can see how this behavior would be prefered in certain circumstances.
Well, a few times, something even weirder has happened.
For example, yesterday, I dragged a folder from Windows called "Burn" into a playlist in emplode. In that playlist, was a track ALSO called "Burn." Emplode treated that track as a playlist and merged the track with the new playlist. So, the older "Burn" track now was marked as modified and the playlist "Burn" was essentially missing.
Deleting the track results in that track and all the tracks in the "mis-added" playlist showing up in a "refs=0" search. Otherwise, except for searching, there is no way to view any of the added tracks from that playlist.
Brad B.
