Looking for a cheap dual-head solution that will output 1600x1200 on both monitors in digital mode. There are many cards that can do this through the analog outputs, but very few can use DVI. The only one I can find is
this one for about $1300.
Another acceptable solution would be a single head PCI card with DVI output. I would use two in one machine and let Windows handle the dual output. Finding a PCI card with DVI is nearly impossible. ATI does make one for the Mac
here. Bruno, do you know if it's possible to flash the firmware to PC? Thanks!
