Uuuh. The patch that I gave Mark did restore the settings, but I know he made some changes to optimise my code, so it may have gotten broken.
I never got any pops either. It only happens going to or from [Off] ?
Check that the underlying eqs bands 9 and 10 are set at 0dB. When you turn the eq to Off, the original bands are restored.
I'll look into this though. Keep the feedback coming
[edit]
Aah, just reread the inital description. The value is restored correctly, but the tone isn't applied until you tweak it....
Ensure that you have notify=1 in your config.ini. Because of the way that the tone controls overload the players eq, the initialisation has to happen after the player has started. The only way that Hijack knows if the player is started is through the notify code.
Tony, can you FAQify this? I have a feeling that it'll crop up a few times...
Edited by genixia (13/03/2002 19:29)
