What you need to do.....
1. Consider a professional installer (trust me, you paid for an
Empeg, pay to get it installed right)
2. VW has a pocket for converting a double din to single with a little bit of storage space.
3. FORGET USING THE MONSOON AMP. Run RCA cables to the trunk, install an aftermarket amp.
I think crutchfield is going to send you the harness for a headunit, something you will not need.
If you read through my posts on my install (and a few others),
interfacing with the monsoon amp is next to impossible
(as stated in my e-mail).
As for cutting the harness, the only part you may need to cut are the speaker leads (my installer built me a harness so we did NOT have to cut this harness, I can have this puppy back to stock in 15 minutes)....you will be bypassing the HU to Monsoon amp cable, so you can leave that in place, untouched.
If you have ANY other questions, just ask. Don't go though the same nightmare I did trying to connect to the &%$%'en
Monsoon system......
VW R32
Empeg 50gig
'Stormy 3 has snuck in a dodgeball' - Stormy 1
