One of the things I'm spending time on in jEmplode 37 is handling errors and fixing tags. There's a much better interface to it now so it will tell you exactly what it found and either attempt to fix it or give you the opportunity to delete it. If you choose not to delete it, it will colorize the offending nodes so you can go in and do something to it later.
Mike
