#100687 - 21/06/2002 10:46 Faster Sync's..... Thank you!
SE_Sport_Driver
A long time ago, I compared USB to Ethernet performance and found that USB was just about as fast and far more conveinient. Once 2.00betaX came along, I tried again and found Ethernet to only be marginally faster (because the real wait was for the database rebuild). Well, now that I've got a LAN at home, I've been using Ethernet exclusively. Most of my sync's are done late at night and I unplug the player the next morning, but today I actually sat there and WOW is this thing fast now! I think it must be a combo of the latest empeg software and of HiJack because even the database rebuild is faster now (and the file transfers as well.)
I just wanted to say THANK YOU and let you know that the work hasn't gone unnoticed!
#100688 - 21/06/2002 11:44 Re: Faster Sync's..... Thank you! [Re: SE_Sport_Driver]
ineedcolor
Loc: Windsor, Ontario Canada
What he said
Since I started using my linksys router, it's been awsome!!!!
My deep appreciation as well.
#100689 - 28/06/2002 10:41 Re: Faster Sync's..... Thank you! [Re: SE_Sport_Driver]
v2beta is way faster (over ethernet) than the older software was.
And JEmplode is apparently faster than Emplode (?).
And new Hijack versions include a slight optimization intended to speed up database sync operations.
Soo.. the combination of all of the above seems to speed things up quite noticeably compared to the old 1.0x software.
#100690 - 28/06/2002 10:43 Re: Faster Sync's..... Thank you! [Re: mlord]
SE_Sport_Driver
Well thank you! I used to go take a nap then mow the lawn while waiting for the database rebuild.... now it is very fast! I think some work in the next release will make CPU usage lower too...
#100691 - 28/06/2002 12:07 Re: Faster Sync's..... Thank you! [Re: SE_Sport_Driver]
csf
Loc: Charlotte, NC
But it will still take me a day or so to sync it with my music backup.
10+40 Gig Mk2a... with Tuner. S/N 040103784 || 2001 Jeep TJ, 60th Anniversary Edition
