#101182 - 24/06/2002 18:52 New HD Cable Installed... Still no Pump
jgriffin
I recieved a new Cable in the mail, installed it, everything went fine. powers on, etc. ive downloaded the image with get right... I STILL freeze on selecting pump device. please help, this is quite aggravating. thanks a lot.
Apparent Newbie
#101183 - 24/06/2002 19:49 Re: New HD Cable Installed... Still no Pump [Re: jgriffin]
justinlarsen
Loc: Petaluma, CA
do you have 1 or 2 drives? if u dont know, is it a 60gb or other size stock?
---- Justin Larsen
#101184 - 24/06/2002 22:47 Re: New HD Cable Installed... Still no Pump [Re: justinlarsen]
jgriffin
1 20gb hd, mk2, i installed cable myself, it powers on, works in car, just wont upgrade or work recognize in emplode b/c of selecting pump device freeze.
Apparent Newbie
#101185 - 24/06/2002 22:54 Re: New HD Cable Installed... Still no Pump [Re: jgriffin]
juenk
Loc: Waardenburg, The Netherlands
What program did you use for downloading the .upgrade image?
Empeg M2A Blue # 010101908 80Gb
Empeg M2A Blue # 030102771 with backlight buttons - Need repair (IDE cable connection on main board) - volunteers?
#101186 - 25/06/2002 06:51 Re: New HD Cable Installed... Still no Pump [Re: juenk]
jgriffin
getright
Apparent Newbie
#101187 - 25/06/2002 07:21 Re: New HD Cable Installed... Still no Pump [Re: jgriffin]
Greetings!
Sorry for being a little slow on the uptake, but could you start from the beginning?
I assume that you were having drive problems and received a replacement cable from David.
Is this a hard drive that you installed yourself? Did you run disk builder against it? Exactly what symptoms are you seeing? Can you post a boot log?
Thanks!
#101188 - 25/06/2002 09:08 Re: New HD Cable Installed... Still no Pump [Re: jgriffin]
FAQ entry on the "Pump" error is here.
Since your player works in the car but not at home, I would suspect a problem with the AC adaptor as described here.
I'll update the FAQ entry on the "pump" error to also include the reference to the AC adaptor.
#101189 - 25/06/2002 09:16 Re: New HD Cable Installed... Still no Pump [Re: tfabris]
Okay, updated the FAQ entry on the Bad Pump error a little bit.
One question to the empeg guys (if you're reading this):
Could the pump error be caused by an incorrectly-partitioned disk drive? Should this person be running the builder-image on the disk drive now to make sure it's partitioned right?
