#105752 - 18/07/2002 09:44 Multi-Insert?
How about when you insert (append or replace) a song into a current playlist, having a choice (possibly by holding down the bottom button while selecting one of the three choices) to hop right back into the directory you were just in, rather than having to start at the beginning (having to choose playlist, etc)?
Just a thought...
#105753 - 18/07/2002 10:05 Re: Multi-Insert? [Re: Tim]
mtempsch
Current behaviour in 2.0b11 is that if you after inserting/appending/... click on the bottom button to get the Playlist menu entry and then hold the bottom button, it'll pop you back to the playlist you last selected from. Not to the exact entry you insert/appeded, but the start of the playlist (the triangle).
#105754 - 18/07/2002 10:37 Re: Multi-Insert? [Re: Tim]
Yes, this is already in 2.0. Please click here for a detailed description of exactly how this works.
#105755 - 18/07/2002 11:23 Re: Multi-Insert? [Re: mtempsch]
Right on! Thats pretty close to what I was looking for. Thanks.
#105756 - 19/07/2002 12:53 Re: Multi-Insert? [Re: Tim]
As noted in the FAQ, but worth a mention, this also works with the Menu button on the remote.
