#12091 - 27/07/2000 05:27
Emplode extras
It would be nice for emplode to back out to the first init dialog "chooser" from within the program without re-starting it.
Murray 06000047 ____________________
Murray
Is it the 'N', or the 'Zero'?
#12092 - 27/07/2000 08:18
Re: Emplode extras
[Re: muzza]
You can do this already. Just close the child window (use the lower of the two X buttons), and then select File|Open.
#12093 - 27/07/2000 08:34
Re: Emplode extras
[Re: Roger]
Interesting. So what you're saying is that each child window is an "opened" empeg?
Does this mean that eventually we'll be able to open two empegs at the same time? Can you say drag and drop? That would be sweet.
Nah, you guys'll prolly disable that on purpose. Oh well.
___________ Tony Fabris
#12094 - 27/07/2000 09:53
Re: Emplode extras
You can open two windows on the same empeg (Window|New), and then drag and drop between them to give you more control over arranging your playlists.
While we could quite easily support opening two players (although there's a bundle of changes that would need to be made to emplode under the hood), it's unlikely that, even if we let you look at both, we'd let you drag and drop between them.
#12096 - 27/07/2000 16:18
Re: Emplode extras
O that function.
woops
i'll just go and stand in a corner and bang my head on the wall for a while
Murray
#12097 - 27/07/2000 16:21
Re: Emplode extras
[Re: Roger]
it's unlikely that, even if we let you look at both, we'd let you drag and drop between them.you could just be a high class napster Murray 06000047 ____________________
Murray
#12098 - 27/07/2000 16:35
Re: Emplode extras
[Re: muzza]
OK, how abouot a sound that plays when a sync has finished?
Murray
#12099 - 28/07/2000 05:04
Re: Emplode extras
[Re: muzza]
There should be one available already. Just go to Control Panel|Sounds, and assign one.
#12100 - 28/07/2000 10:04
Re: Emplode extras
[Re: Roger]
There should be one available already. Just go to Control Panel|Sounds, and assign one.Whaddya know, there they are. I'll be damned. The only reason I never heard them on my system is because they default to Window's wave files like tada.wav and chord.wav, irritating sounds which I'd long since deleted off of my hard disk. Time to go assign them to something more irritating, like Monty Python or MST sounds... ___________ Tony Fabris
#12101 - 28/07/2000 10:49
Re: Emplode extras
I suggest:
"Ah! I see you have the machine that goes *ping*!"
(Monty Python's Meaning of Life)
#12102 - 28/07/2000 11:13
Re: Emplode extras
[Re: altman]
Heh, my "incoming mail message" sound is the bit from "Grail" where the boy imprisoned in Swamp Castle shoots an arrow out of the window with a message attached. You hear the arrow streaking through the air, piercing the chest of Lancelot's paige, and the paige exclaiming, "Message for you, sir!" as he falls to the ground...
#12103 - 29/07/2000 04:11
Re: Emplode extras
DAMMIT You see haw good these empeg folks are!!!?
I was expecting something in the program prefs (maybe that would help too!).
Murray
#12104 - 04/08/2000 15:04
Re: Emplode extras
[Re: muzza]
OK What about an undo function eh? i seem to remember asking for it hereMurray 06000047 ____________________
Murray
