#121501 - 17/10/2002 06:04 Timecode display - small wish
tms13
Loc: Lochcarron and Edinburgh
IWBNI the "1/Time" button on the remote would only chang the timecode setting when the timecode is visible.
If the timecode is not visible (Info:Off or Info:Transient), pop up the timecode without changing it, and if Time is pressed again while it's visible, then change it.
This is consistent with the UI for other gadgets (e.g. my home stereo's sleep-timer works like this) and is useful in the common case where you want to look at the timecode without changing it (otherwise it's seven presses to cycle round, or two long-presses on the front panel).
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#121502 - 17/10/2002 06:48 Re: Timecode display - small wish [Re: tms13]
jets
Loc: Toronto, Canada
if the time code isn't visible while in transient a quick press of 'select mode' on the remote will re-seed the visual so you could see it. just a thought...
It seemed like a good idea at the time.
#121503 - 17/10/2002 07:58 Re: Timecode display - small wish [Re: jets]
tms13
Really? When I re-seed the visual using Select Mode in Transient, I see artist and title but not timecode. Which version of the player software are you using, jets?
Toby Speight
#121504 - 17/10/2002 09:04 Re: Timecode display - small wish [Re: tms13]
jets
My bad. Thats right! **smacks himself silly** I just checked and I'm guiilty. No timecode doing what I said above.
#121505 - 20/10/2002 20:22 Re: Timecode display - small wish [Re: tms13]
rjlov
Loc: Melbourne, Australia
If I recall correctly, this is already in the internal bug database...just checking...
Yes, #1464. So, the empeg guys have it in their records, anyway.
Richard.
