#123545 - 29/10/2002 17:49 Rio S50
I played with a coworkers Rio S50 earlier today, and I am impressed. The little device had so many things hidden away in the software, and getting around was easy. The screen also displayed an impressive amount of info.
Overall, it seems like a good solid state player, and it uses standard memory formats (MMC) for expansion.
One thing I couldn't figure out though, can it use the SD cards? I can't find any 256mb MMC cards, but 256mb SD cards exist.
#123546 - 29/10/2002 23:39 Re: Rio S50 [Re: drakino]
Loc: Los Angeles, CA
are SD and MMC the same format?
Click Here
#123547 - 29/10/2002 23:51 Re: Rio S50 [Re: image]
btw, to the empeg guys...
what was the deciding factors to use MMC instead of CF, which can go up to 1gig nowadays?
#123548 - 30/10/2002 00:05 Re: Rio S50 [Re: image]
matthew_k
Objection, Asked and Ansewered. Size - the players couldn't be as small as they are with compact flash...
#123549 - 30/10/2002 01:29 Re: Rio S50 [Re: matthew_k]
I've seen the S50. I think that if cleverly designed, it could have been the same size and accepted a CF card. I think there were other engineering reasons for the choice other than size.
#123550 - 30/10/2002 01:55 Re: Rio S50 [Re: image]
They're the same except that SD cards are allowed to be slightly thicker (that's why big capacities only come in SD).
#123551 - 30/10/2002 02:00 Re: Rio S50 [Re: tfabris]
I dunno, those things (especially S30/S35) are pretty full, and this sort of device needs a good strong (thick) shell in case of being dropped etc.
#123552 - 30/10/2002 04:18 Re: Rio S50 [Re: drakino]
If you install version 1.20 of the software (available from the sonicblue support site) it will work with SD cards. We have tested with cards up to 512MB so far.
#123553 - 30/10/2002 04:21 Re: Rio S50 [Re: tfabris]
CF could perhaps have been squeezed into an S10/S50, but not an S30/S35. Clearly products of this nature are going to continue decreasing in size so having dropped the unpopular proprietry backpacks it seems very sensible to go with the smallest format commonly available.
#123554 - 30/10/2002 04:23 Re: Rio S50 [Re: peter]
In fact there are many differences. The one that is of most consumer interest is that SD is much faster than MMC.
