#124638 - 04/11/2002 05:26 problems with kenwood-remote
teemcbee
i've got a problem with my mk2 and the kenwood-remote..
i've already figured out the problem a while ago but i thought it may be a weak battery in the remote unit.
the problem shows up as following:
sometimes when i press any key on the remote it's recognized by the empeg, other times it is not. i replaced the battery with a totally new one - but i still have the same problem.
sometimes about 3 or 4 button presses are accepted, then i can press as many buttons as i want and nothing happens at all..
i've got the v2.0 b13 and the hijack-kernel 2.91 installed.
anyone an idea what the problem could be?
TeeMcBee
#124639 - 04/11/2002 10:35 Re: problems with kenwood-remote [Re: teemcbee]
Tee, did you already go through all the stuff here?
#124640 - 06/11/2002 11:03 Re: problems with kenwood-remote [Re: tfabris]
teemcbee
yes, i tried those things - als i've told - i've got v2b13, a new battery and today i tried to bend the contacts a little bit.. i tried the remote while the player was on the table connected to AC power... and i was glad it worked for every keypress...
but then i put it back into the car... and it didn't work any more... so it seems it has something to do when in the sled... so maybe it is any software-related problem?
any further idea? should i maybe uninstall the hijack kernel? any other things to do?
TeeMcBee
#124641 - 06/11/2002 12:29 Re: problems with kenwood-remote [Re: teemcbee]
rtundo
Loc: Albany, NY
If you have another compatible remote from some other equipment you could try to see if it is the remote or the player. If you don't have another Kenwood/compatible remote just disregard this suggestion
#124642 - 06/11/2002 13:02 Re: problems with kenwood-remote [Re: rtundo]
Actually, it can be any consumer IR remote in the proper frequency range with the Hijack "Button Codes Display" feature.
