#134288 - 10/01/2003 13:49 upgrade
toutsuite
Loc: California
I just got a second unit and was trying to load the 2.o beta 13 into it which I loaded on my other unit. I keep getting an error that says player not found check serial connection. It starts to do the update and at the very end is when the errror shows up. I have checked everything twice, ran a check on serial port and it is working. the unit now has 1.02 on it what am I doing wrong?? Thanks Tim
#134289 - 10/01/2003 15:19 Re: upgrade [Re: toutsuite]
Do you have something else open on the port, like a hyperterm session? Verify with hyperterm that everything is working, then exit hyperterm. Sometimes that verification step sets up the serial port communication settings.
#134290 - 10/01/2003 16:31 Re: upgrade [Re: pgrzelak]
toutsuite
Loc: California
I have disabled hyperterminal, I even loaded the b13 disc on my laptop and tried to update from there, it gets the same error player not found. check serial connector
#134291 - 10/01/2003 18:15 Re: upgrade [Re: toutsuite]
SE_Sport_Driver
I'd check the FAQ for more troubleshooting info, but make sure you are using the serial cable that came with the empeg. It is a "null modem" serial cable (or something like that). I bought a serial cable from Radioshak once and it wouldn't work because it was a standard cable and not the null modem type.
If the cable works for hyperterminal or Tony's logo editor then the cable is not the issue.
#134292 - 10/01/2003 18:17 Re: upgrade [Re: toutsuite]
Make sure that there's no program attaching to that serial port, like maybe a Palm connectivity process. Can you open the serial port with Hyperterm and see the empeg boot?
#134293 - 11/01/2003 10:28 Re: upgrade [Re: wfaulk]
toutsuite
Loc: California
I got frustrated and tried something else on the serial port with no output.. Good ol XP... did a system restore and everything started to work againg..Now my next challenge is to get the ethernet working so I can get rid of the Porsche at boot up,,
#134294 - 11/01/2003 23:39 Re: upgrade [Re: toutsuite]
MP3944
Loc: Grove City, OH, USA
Now my next challenge is to get the ethernet working so I can get rid of the Porsche at boot up.
Now why would you want to do a thing like that?
1987 Porsche 944 http://www.heeyyguys.com
#134295 - 12/01/2003 00:58 Re: upgrade [Re: toutsuite]
Happy Birthday Daria
That's just such a bizarre thing to read.
