#146186 - 27/02/2003 18:24 2000 Dodge Intrepid Install, Dash and Trunk Photos
CHiP
-CHiP
#146187 - 27/02/2003 18:35 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: CHiP]
njdboy
Loc: San Jose, CA
very nice! excellent job and really cleanly done on the dash.
#146188 - 28/02/2003 08:45 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: njdboy]
Looks great! You may want to consider one of Robricc's black sleds when they come out. That way the edges of the sled won't be so obvious when the unit is removed. Nice custom work on the dash piece and the trunk though.
#146189 - 10/03/2003 14:13 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: CHiP]
smitty225
Loc: Maryland
Nice install. As low in the dash as it is, do you have problems seeing the top left portion of the display?
10gig MK2a - Blue Screen s# 040103813
#146190 - 10/03/2003 14:20 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: smitty225]
CHiP
Actually, i do.... but i got used to it, and its no problem if you lean back just a few inches... if you like your seat back, it wont be a problem, its SOooooo close, that some drivers will notice it and others wont, depending on how far your seat goes up.
I was going to angle it up in my initial idea, but it was too hard once i opened everything up.
thanks for the feedback.
-CHiP
#146191 - 10/03/2003 16:21 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: CHiP]
If you haven't already done so, you might want to try the technique outlined in this post. It worked well for me.
#146192 - 10/03/2003 16:39 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: CHiP]
SE_Sport_Driver
How did you feed the empeg's output to your factory headunit?
#146193 - 11/03/2003 07:46 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: SE_Sport_Driver]
It looks like Blitzsafe offers an AUX input adapter for Chrysler, but I'll assume he didn't know about that.
Instead I'm going to speculate that he ran the factory head unit through a line-level converter and then into the AUX input on the Empeg. Only down side to that is that the radio and tape don't work without the empeg in.
EDIT: Nevermind...he posted what he did below.
#146194 - 11/03/2003 10:47 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: SE_Sport_Driver]
CHiP
I used a Sony relay unit found on this site, to switch the line out from empeg to stock. The stock is connected to a speaker-to-line level converter first. I’m sure you can find the relay if you look around on this site. If you are interested, I’ll get more info on the relay. Does that help?
-CHiP
#146195 - 11/03/2003 10:49 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: tanstaafl.]
CHiP
oooh. I'm not sure if i want to try that! Its really not that bad in my car.
-CHiP
#146196 - 11/03/2003 10:57 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: CHiP]
More info on that relay (Sony XA-39) here.
I forgot about that option. That's a good solution to the problem. Where did you happen to get it?...according to that thread, they are no longer available....
#146197 - 11/03/2003 11:02 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: JBjorgen]
CHiP
Yeah, that's the one, this way, i can run the stock radio, tape, (cd changer, once i connected it up again) when the empeg is home. I live in NJ, so its i dont like to leave the empeg in the car when its cold out, and if i forget and leave it at home, or for a short trip somewhere and its 20 below, i rather leave it home and listen to the stock system. This has worked out great for me so far.
-CHiP
#146198 - 11/03/2003 11:03 Re: 2000 Dodge Intrepid Install, Dash and Trunk Photos [Re: njdboy]
CHiP
Thank you!
-CHiP
