I hate to ask such a question, but here it goes. I have a pair of 802.11g access points that will work together to blanket a house in access. One will be in the basement and the other in the attic.
I am looking for a guide to setting up the access points so that as you roam about the house, your NIC will pick whichever of the two APs is giving the strongest signal. In other words, both access points have the same SSID, and WEP key. The way I understand it is, you only have to give the APs seperate channels (5 channels apart would probably be best). Is that all I have to do? I want to make sure I do this right the first time.
