#15422 - 25/08/2000 07:45 DHCP Address?
ClemsonJeep
Loc: Ashburn, VA
I donno if it is possible now, but if not, could it be made so that you can retrieve what IP the empeg has been assigned by DHCP from the menu system?
That way I wouldn't have to keep changing the static IP when I take it from work/home, allowing me to use DHCP. I could just navigate through the menus to find the IP it was assigned, then telnet to that IP when I exit the menu system (Quit).
Let me know if this is possible/probable/or has already been implemented? :)
(O|||||O)
(O|||||O)
#15423 - 01/09/2000 18:35 Re: DHCP Address? [Re: ClemsonJeep]
rexkp
Take a look at my empeg page. You'll find the building blocks there.
#15424 - 02/09/2000 04:07 Re: DHCP Address? [Re: ClemsonJeep]
This is in 1.1, the about box shows all the necessary info.
