#155867 - 17/04/2003 11:04 SVee6 GPS board?
Loc: Los Angeles, CA
a while back, someone (dbrashear i believe) was encouraged to develop an interface board for this gps unit. was wondering if this ever materialized... and if not, does anyone want to build me one for a fee? i'd really like to start using a gps in the car.
#155868 - 17/04/2003 11:59 Re: SVee6 GPS board? [Re: image]
My opinion:
If you want to use GPSapp, then just buy a proper 12v GPS receiver that you can plug into the serial port. If you've got one that requires a special interface board before it can be plugged in, you've simply got the wrong one.
#155869 - 17/04/2003 12:34 Re: SVee6 GPS board? [Re: image]
Daria
Yeah, I dropped it due to time. If you do it, I won't object, I don't know when I'll have time to deal.
#155870 - 17/04/2003 16:31 Re: SVee6 GPS board? [Re: image]
siberia37
Loc: Tacoma,WA
If you just need to do 5v serial to 12v serial conversion then you can use this little module. You still have to do a little legwork but it just involves connecting the right cable on the module to the right place on the GPS board, you'll also need a 7805 for a power source. You can do it almost without soldering if you don't mind splicing wire.
