#167573 - 25/06/2003 10:50
High-flow toilets
I am buying a house and it is pretty old. The house was built in 1947 and the toilet (which looks great and still runs) manufactured in 1946. The only problem is the size. People in the 40s must have had really small asses.
I liked the late 70s model in my old apartment. Never gave me a problem and it had a nice, ass-friendly size.
However, in the US, it is illegal to sell a normal "high-flow" toilet since some point in the 1990s. My parents are in a new house and have low-flow toilets. They really blow.
I know that high-flows are still sold in Canada. Does anyone know what the problems with buying a toilet in Canada, loading it into my car, and coming back into the US might be? I think I might be alright, but being busted at the border for toilet smuggling is kinda embarassing. I would like to avoid a confrontation.
#167574 - 25/06/2003 11:08
Re: High-flow toilets
[Re: robricc]
When my parents were redoing two bathrooms in our house, it was around the time when that law was just put into place. The contractor asked if we wanted to get some of those imported from Canada. Somehow, toilet smuggling sounded too bizzarre, so they went with the new low-flow. They certainly are "crap."
So I think you can do it, and it might be easier for you (you're in NY, right?).
#167575 - 25/06/2003 11:12
Yeah, I'm in NY. Montreal is about a 6 hour drive.
Maybe I could ask a plumber about it. They would probably know where to get a black market toilet. The thing is I will be going to Canada the weekend after Amersfoort. It would be convenient to pickup a toilet then plus I wouldn't have to pay drug-dealer prices for it.
#167576 - 25/06/2003 11:14
[Re: robricc]
The absurdity of this thread is mindboggling
#167577 - 25/06/2003 11:16
[Re: loren]
The absurdity of this thread is mindboggling Maybe for a skinny guy like yourself, but those of us with larger posteriors appreciate Rob's quest for a bigger shitter.
#167578 - 25/06/2003 11:16
[Re: loren]
Agreed! But, at the same point, I would rate it no less illegal than all of the senior citizen bus tours hopping the border to pick up prescription drugs.
#167579 - 25/06/2003 11:20
[Re: pgrzelak]
oh, don't take me wrong, i don't doubt the need is there, but just the sheer idea of having to smuggle a freakin' toilet is hilarious. What is the link between high flow and ass width anyway? Don't they make larger diameter toilets in low flow design? And not all low flows suck by the way.
#167580 - 25/06/2003 11:23
[Re: loren]
Absurd!?!?!
My persuit of happiness involves being able to own a 5 gallon flush toilet. What's wrong with that?
#167581 - 25/06/2003 11:25
[Re: loren]
The main thing I want is the flow. The toilet in the house already has that. However, it is small (although I have not perfomed a test drive yet).
I want a large toilet that is also high flow. That is illegal in the country for some moronic reason.
#167582 - 25/06/2003 11:27
[Re: robricc]
After doing some more research, it seems I may be able to smuggle it in without a problem.
As long as the house was built before 1996, you can install a high-flow toilet. However, there is no where in the US you can buy one. So I would have to get it from Canada.
#167583 - 25/06/2003 11:30
[Re: robricc]
Loc: New Orleans, LA
What they (lawmakers) don't realise is that you have to flush a low-flo toilet 3-4 times to get it to "Do the job" properly, thereby eliminating the water savings. The only thing worse to me are low flo shower heads. The first thing I do when I buy a shower head is take it apart and destroy the flow limiter. Next they'll try custom fitting tubs so a bath can use less water. Sheesh.
#167584 - 25/06/2003 11:31
[Re: robricc]
Ummmm.... I'm not sure how to approach this.
Really, the bowl itself need not be so big. You can get seats that are bigger than the edge of the bowl but that have bumpers that are large enough to sit on the bowl comfortably. The ones I've seen look more like half lipsticktubes that run with the radius of the seat than squat cylinders/pucks.
YMMV.
#167585 - 25/06/2003 11:34
[Re: lectric]
Supposedly, the well-manufactured low-flow toilets these days don't have so much of a problem. This is apparently due to active improvements, like using pressurized water, better modelling so that the suction works better, and, most simply, polishing (but not glazing, usually) the exit trap.
Of course, that doesn't help when the building's plumbing won't keep up without the greater water flow, as is often the case in older houses.
#167586 - 25/06/2003 11:35
[Re: robricc]
Jeez, but I just LOVE this damn' BBS
#167587 - 25/06/2003 11:43
Possibly a new seat might be enough, but I think the bowl would have to be bigger too for other comfort reasons.
Since I will be in Canada anyway and I will have my Saab with the covered hatch back up there, I think I want to take one back anyway. I'm sure I could sell it in a dark alley if I end up not needing it.
#167588 - 25/06/2003 11:49
[Re: tonyc]
Loc: Georgetown, TX USA
Bigger in diameter and taller, like the handicapped stall toilets. I don't like my knees in my face while doing my business....
Rob, I assume you've seen the King of the Hill where Hank takes on the City Council over low flow toilets? They had a secret stash of high flows to bribe folks who complained, but Hank, being the honest propane and propane accessory salesman, would have no part. Dale on the other hand, would have gone for the bribe I bet...
Dave Clark
Georgetown, Texas
MK2A 42Gb - AnoFace - Smoke Lens - Dead Tuner - Sirius Radio on AUX
#167589 - 25/06/2003 11:50
[Re: robricc]
Loc: Boston, MA USA
I have a solution for you.
How about changing your diet?
That way you have the potential to solve two problems at once.
--------- //matt
#167590 - 25/06/2003 11:50
[Re: robricc]
Loc: Manchester, NH
My parents recently redid their bathroom. We have a 5 gallon toilet that we love that was manufactured in 1949 and still in "mint" condition.
When we removed the toilet to replace the florring with new ceramic tile, we noticed (besides the smell) is that the flange was busted. We had the plumber come and replace the flange and then we went looking for another toilet.
The toilets out there are only 1.6 gallons and therefore would not suit our needs. What you have to realize is that there are 7 people that use this toilet including 6 men daily.
We ended up having the plumber just reinstall the 5 gallon toilet because it still worked and we didn't have to spend $200 dollars on a new toilet.
I know that toilets are less expensive than that but the Pressure Assisted ones are in that range. If we were going to get a new toilet, it would have been a pressure assisted one because it uses air pressure to push the water out of the tank and provides more pressure per gallon allowing for fewer flushes on the government regulated 1.6 gallons.
If you are looking into new toilets, take a look at the pressure assisted ones. We did notice that they only come with a 5-year warranty which makes me worry because it has additional proprietary parts not found in other toilets.
#167591 - 25/06/2003 12:02
[Re: ithoughti]
You met me. My ass isn't huge (not that you were looking).
I just want what I want.
The pressure assist ones sound like an option. What do they use to push the water faster? Does it have to be plugged in to electricity?
#167592 - 25/06/2003 12:06
[Re: tonyc]
I am with you (see my post in big-head thread; my ass is not far behind, so to speak).
I have noticed that US and British toilets are of rather different design than, say, Italian or German ones (which we prefer here). We on Continent don't poop into a huge pool of water (which in the process sprinkles your behind) that uses mid-size Maelstrom to flush. Ours use less water, but English-speaking ones are easier to keep clean (and, besides, A.L.F. finds them interesting)
This board is crazy!
Dragi "Bonzi" Raos
Q#5196
MkII #080000376, 18GB green
MkIIa #040103247, 60GB blue
#167593 - 25/06/2003 12:06
[Re: schofiel]
Jeez, but I just LOVE this damn' BBS Well, I'm starting to get alarmed by the topics of some of the recent messages... Just in the last few days, we've had members lamenting the fact that they have big bellies, big heads, and, with this thread, big asses. I'm not sure what the next step is, but I'm not sure I wanna be around when it happens..
#167594 - 25/06/2003 12:12
[Re: robricc]
Loc: Manchester, NH
The pressure assist ones have a poly tank inside the actual tank. It doesn't run off of electricity so no need to plug it in.
It holds air and as it fills up with water, the air compresses and then when you flush this compressed air helps push the water out quicker.
Another positive to this is that these don't "sweat" like a standard porcelain tub because the water is actually held inside the poly tank.
#167595 - 25/06/2003 12:14
[Re: robricc]
Loc: NH USA
If a used toilet doesn't give you the willies, then what about one from a plumbing salvage operation? Most likely it'd be an older model and would save you an interesting US Customs conversation: "Yes sir, a toilet..."
-Zeke
WWFSMD?
#167596 - 25/06/2003 12:15
[Re: robricc]
The pressure assist ones are nice and they do get the job done. The best one's I've seen were at the Disney Hotels in Florida. However nothing beats an old 1940's-50 toilet for getting the job done and just to total effect. I have a 40'-50's toilet and the tank broke. I glued and wired it back together!
The hell with a new one!
The pressure assist ones sound like a jet taking off and they can even splash stuff out if turned up too high.
Edited by Redrum (25/06/2003 12:18)
#167597 - 25/06/2003 12:18
[Re: robricc]
Toilet smuggling the mind boggles where would you hid it, i suppose you could take out the driver seat and them sit on it while going through customs
Aberdeen Scotland
#167598 - 25/06/2003 12:22
[Re: thinfourth2]
I think toilets are sold in two pieces, so I think I could fit both in the trunk. I am not sure because I have never gone toilet shopping.
Here's a funny usenet post about this topic.
#167599 - 25/06/2003 14:14
[Re: tonyc]
You should see the tee-shirt order list....
#167600 - 25/06/2003 15:10
[Re: robricc]
Loc: Greenhills, Ohio
I just gave mine away a few weeks ago, too bad
It did flush alot better than the new expensive one but the cheap Kohler downstairs does a pretty good job, almost as good as the old one. I have to remember when scooping litter boxes to dump it in there, I've already clogged the upstairs one up.
Laura
MKI #017/90
whatever
#167601 - 25/06/2003 17:32
[Re: schofiel]
Loc: TX
Almost on subject, but has anyone read the book "Flushed with Pride"
It is the supposed history of the flush toilet.
One of the early innovators was one "Thomas Crapper"
Hell of a way to get your name reused.......
the chewtoy for the dog of Life
#167602 - 25/06/2003 17:50
[Re: ashmoore]
has anyone ever put a long piece of asswipe about 20 feet long in one of the air presure toilets.LOL it sucks it up quick,try it next time you go on a cruise ship,it's really funny my 4 year old keeps trying it at home.
i
040103958 60g
