#170923 - 17/07/2003 04:00 Empeg mounting angle
Blipman
Loc: Melbourne, Australia
I note the user manual states that an Empeg should not be mounted at more than 16 degrees to the horizontal.
I'm planning on mounting it flush with the dash in a 300ZX, which has quite a sloping dash and will possibly exceed 16 degrees.
What is the reasoning behind the manual stating this limit? Is it a hard disk issue? What can I expect.... constant skipping, occasional skipping, damage to the disk?
Ben
#170924 - 17/07/2003 04:01 Re: Empeg mounting angle [Re: Blipman]
It's to do with the shock mounting in the empeg. If you mount it at an odd angle then there is a chance that the HD tray will come off the mountings.
#170925 - 17/07/2003 04:29 Re: Empeg mounting angle [Re: Blipman]
thinfourth2
That said altman has one in a NSX which is at a pretty acute angle and if he is confindent enough you should be fine so don't worry unless you have a MK1 with less secure drive rubbers.
#170926 - 17/07/2003 06:43 Re: Empeg mounting angle [Re: thinfourth2]
Mine's been mounted at about 30 degrees for a couple years and it's worked great. And this is not a smooth riding vehicle...it's a 15 yr old SUV. YMMV, so don't blame me if your drive goes belly up. It comes down to the fact that I'd rather be able to see the display on my Empeg and replace a hard drive occasionally should the need arise. Luckily it hasn't.
#170927 - 17/07/2003 08:04 Re: Empeg mounting angle [Re: Blipman]
bonzi
Apart from shock mounting issues, there it the matter of drive spindle bearings. If you rotate the drive when spun up in any plane other than the one paralell to platters (i.e. perpendicular to drive axis), the bearing will be loaded laterally, for which it was not designed, theoretically shortening the drive's life. As tha car mostly rotates in horizontal plane (hopefully), the drive will feel best if it itself is horizontal.
However, I don't recall anybody reporting a drive failure that could be attributed to this.
#170928 - 17/07/2003 10:01 Re: Empeg mounting angle [Re: Blipman]
schofiel
You may find this writeup useful for the 300ZX.
As regards the angle: this console was about 20 degrees. What that means is that the drive tray inside the player is no longer horizontal. 16 degrees was determined by the size of the drives and tray inside the player (due to the DIN case size), and common installation angles in consoles. The drive tray hangs by 4 rubber, conical shock mounts. These are designed to work in tension, vertically. If you mount the player so that the tray is no longer horizontal, then the tray "swings" back and forward, instead of up and down, inside the player. Hence, on a large shock, the tray tends to knife forwards against the display cable, and back against the power and audio harness. The shock rating of the drive assumes vertical shock, so if a shock occurs off-axis, then you've no idea what damage will occur to the drive, which could in the end shorten drive life.
You shouldn't be too worried about being slightly off 16 degrees: experience seems to show that it doesn't affect drive life too much - for example, my own Mk 1 is mounted horizontally (therefore putting the drives at a -16 degree angle) in a Mini - and despite two crashes, a broken wheel rim in a pothole, and the standard suspension quality of the Mini (ie., none whatsoever) the drives are the original ones, and seem to be in good order after some 4 years' use. If you mounted vertically so that the shock mounts are effectively useless, then yes, I would worry
Maybe you should mail ANdrew (the owner of the ZX in the install I did with him) to see what his experiences have been.
#170929 - 17/07/2003 18:35 Re: Empeg mounting angle [Re: bonzi]
Theoretically....
But given that the huge majority of drive failures are caused by head crashes or failures of the electronics, it isn't anything I'd worry about.
I don't think I've ever heard of a drive failure caused by worn out spindle bearings.
#170930 - 17/07/2003 19:08 Re: Empeg mounting angle [Re: tanstaafl.]
It happens a lot in older Unix and VAX machines. I'll bet quality on such things has improved dramatically since then, though.
#170931 - 17/07/2003 20:23 Re: Empeg mounting angle [Re: tanstaafl.]
Honestly, I never know why a given drive fails when it does. All I ever know is that I start gettting errors and I replace the thing. For all I know, every failure I've had could have been spindle bearings.
Or gnomes.
I'm starting to wonder about gnomes possibly being the culprit in many things. Sometimes I think I catch a glimpse of one out of the corner of my eye, but it scurries out of sight before I can make a positive identification.
#170932 - 17/07/2003 21:31 Re: Empeg mounting angle [Re: Blipman]
fusto
Loc: Lummi Island, WA
I have mine mounted completely vertically in my jeep.
Its mounted in the console between the seats.
So far no problems. Worse comes to worse, the drive craps out, and I clone my spare.
An acceptable risk...
#170933 - 18/07/2003 01:15 Re: Empeg mounting angle [Re: tfabris]
Or gnomes.
Or pixies, nasty little fsckers. I swear they keep punching reset on our server in the middle of the night.
#170934 - 18/07/2003 01:33 Re: Empeg mounting angle [Re: tfabris]
Daria
Or gnomes.
1) Mess up Tony's disks
2) ?
3) Profit.
#170935 - 18/07/2003 08:23 Re: Empeg mounting angle [Re: tfabris]
Captain_Chaos
Loc: Amersfoort, The Netherlands
Or gnomes.
You're confused. Gnomes don't exist.
What you saw was a gremlin.
#170936 - 18/07/2003 09:22 Re: Empeg mounting angle [Re: Daria]
2) ?
3) Profit.
ROFLMAO
#170937 - 19/07/2003 07:39 Re: Empeg mounting angle [Re: Blipman]
speedy67
Loc: South-West-Germany
PM Dr_DOS, he has a 300ZX, too.
You should find pics in robriccs Album from the Euro Meet 2003....
cheers, Thomas
cheers, Thomas new owner of the MK1 00123 MK2 12GB 090000815 (my first one) MK2a 040103735 (from 303) and ???
#170938 - 26/07/2003 17:28 Re: Empeg mounting angle [Re: Blipman]
dr_dos
Loc: Bendorf, Germany
Are you talking about a Z32?
I haven't had any issues mounting the empeg in my dash that way so far.
