#174859 - 11/08/2003 23:24 More Riot Problems....Spares Needed....
OK, my Riot is now Locking at "Battery Manager Setup" and dies if I pull the Charger out. Any ideas ???
At this point, I'm totally ready to rip the thing apart, where can I get a spare battery pack from ???
Thanks in advance.
Cris.
#174860 - 12/08/2003 04:14 Re: More Riot Problems....Spares Needed.... [Re: Cris]
Unlikely to be the battery pack per-se causing the lock, as it's not intelligent. The player falling over when you pull the charger out does point to a dead battery though - or one which has a bad connection.
I'd check the pack voltage/connections first. The pack is a standard panasonic part, though the connector may be different requiring a little wiring work.
#174861 - 12/08/2003 10:23 Re: More Riot Problems....Spares Needed.... [Re: altman]
Cheers Hugo !!!
OK I have it in bits now, connections seems fine, can't find a model number to order a new battery, any clues ??? Could the boot be stopping because it can't see the battery at all, the same thing happens if I remove the battery pack altogether. I will have to get my meter from work to check the pack voltage.
On a seperate note, I was surprised to see no shock protection for the HD at all !!! Is this the same with the Karma ???
Cris.
#174862 - 18/08/2003 08:53 Re: More Riot Problems....Spares Needed.... [Re: Cris]
elperepat
Loc: Qc, Canada
Hi!
I also have a riot with battery problem. I've taken it appart and removed the "plastic" on the battery to find it's a CGR18650HG
In fact, it's a samsung battery, model number ICR18650-18.(HG is not written on the battery, but the 18 written at the end of model number must stand for 1800 mAh. Dimension are corresponding: 0.7" dia by 2.56 " long.
Now, we've got to find a way to get some of those... any idea? Panasonic Canada tell that their distributor for Canada is digikey, but they don't have that model of battery.
Help! ;-)
Patrick
Patrick
#174863 - 18/08/2003 08:58 Re: More Riot Problems....Spares Needed.... [Re: elperepat]
Alas my Riot is no more
It fell off my bench onto the floor when I was tidying up, it was already in bits, but it pulled and snapped the display cable when it hit the floor.
Anyway, its not all bad, the Empeg is going to get a shiny new 20Gb upgrade, so bring on the KARMA !!!
Cris.
#174864 - 18/08/2003 15:10 Re: More Riot Problems....Spares Needed.... [Re: Cris]
loren
Did you guys try this?
Oh, and while i'm at it... does the new Music Manager app for the Karma and other new Rio players work with the Riot?! If so where can i download it!!??
|| loren ||
