#174906 - 12/08/2003 07:52 Can anyone give me some motherboard/processor help
puckalicious
I have given up on Intel's "support" information, and I don't know where else to go, I hope someone can help me here. I have an older Intel board, D815EFV, and I want to know if it supports the Tualatin core (.13) Pentium III's in the 370 pin FCPGA configuration. I don't have any CPU's around to test it out, and I was going to buy one but it would be nice to know first.
#174907 - 12/08/2003 08:04 Re: Can anyone give me some motherboard/processor help [Re: puckalicious]
robricc
Even if it doesn't, you can buy an adapter from Powerleap
#174908 - 12/08/2003 08:52 Re: Can anyone give me some motherboard/processor [Re: puckalicious]
Based on this, it depends on the revision of your board. Use the information at the bottom of that page to find out.
Any motherboard that says it can support 1.13 or 1.2 processors at Intel.com means the board supports Tualatin CPUs. There were no other versions of 1.13 or 1.2 P3 chips.
#174909 - 12/08/2003 10:10 Re: Can anyone give me some motherboard/processor [Re: drakino]
puckalicious
Thanks for the replies!
Drakino, my board number is below the A51500-700 number. Does this mean it won't support the 1.13 or 1.2 no matter what? Unless I buy that adapter?
#174910 - 12/08/2003 10:14 Re: Can anyone give me some motherboard/processor [Re: puckalicious]
Tualatin processors have different voltage needs than the older FC-PGA chips. You'd probably end up blowing the chip or motherboard if you plugged it straight in. The newer board probably detects if it's a Tualatin and then changes the voltage on the IO or whatever pins that were changed.
You have to get the adapter basically
#174911 - 12/08/2003 15:05 Re: Can anyone give me some motherboard/processor [Re: puckalicious]
You must buy the adaptor. The Tualatin uses a different input voltage then the older P3 chips did. It's unfortunate that very few consumer motherboards come with removable voltage regulator modules, the component that feeds your CPU power. In many cases, these fail before other components, and making them removable would allow for either easially fixable motherboards, or upgradable motherboards as well.
