#174945 - 12/08/2003 10:16 Empeg Greeting PCM file Froze player
michael_corleone
Hey all,
I added this line after converting a wav file to pcm through sox as said. File is about 1.25 mb:
;@EXEC_ONCE "/drive0/var/pcmplay < /drive0/var/amanda.pcm"
when i removed the quotes my empeg hung after the time was said. So i had to hyperterm back in and remove it. Does anyone know why this happened? or does anyone know a different way i should be putting it into my config.ini?
also does anyone have any good pcm startup greeting files? and if so where are they posted?
thanks all
#174946 - 12/08/2003 19:40 Re: Empeg Greeting PCM file Froze player [Re: michael_corleone]
davec
Loc: Georgetown, TX USA
Will this work?
;@EXEC_ONCE "cat /drive0/var/amanda.pcm | /drive0/var/pcmplay"
Or add the command (minus the ;@EXEC_ONCE and quotes) to the ttsclock script per this post.
Dave Clark Georgetown, Texas MK2A 42Gb - AnoFace - Smoke Lens - Dead Tuner - Sirius Radio on AUX
