#186505 - 23/10/2003 17:52 MK1 grounding leads
fbleagh
i sold my old mk1 to one of my friends, who took it to somewhere to get installed.
the install place threw out the ground rca leads.
can someone pls post a wiring diag for those so i can make some new ones for him
cheers
#186506 - 23/10/2003 17:58 Re: MK1 grounding leads [Re: fbleagh]
They simply have a ground wire attached the shrouds of the RCA connectors. That's all. No wiring diagram necessary.
#186507 - 23/10/2003 18:02 Re: MK1 grounding leads [Re: tfabris]
fbleagh
so it would look like
rca end1 other end
signal ------- signal
ground -------ground
car earth
#186508 - 23/10/2003 18:06 Re: MK1 grounding leads [Re: fbleagh]
Yes.
#186509 - 23/10/2003 18:08 Re: MK1 grounding leads [Re: tfabris]
Oh, and by the way...
If there's no noise problems with the Mk1 installed, then you don't need them. You didn't say whether you wanted them because of noise problems.
