#189438 - 13/11/2003 22:50 Projection Clock
ineedcolor
Loc: Windsor, Ontario Canada
Hello All
After searching high and low for a number of days, I can't seem to find a decent projection clock...requirements are: modern/unique looking, reasonably priced and a larger display. eBay, Oregon Scientific, the Sharper Image et al all seem to have the same boxy, boring models...Has any one stumbled across a site that has something different listed for sale? TIA
#189439 - 14/11/2003 01:29 Re: Projection Clock [Re: ineedcolor]
mtempsch
A quick look around the swedish sites that might carry stuff like this gives the following links (what are you using for power, 110/120 or 220/230V - some of the clocks in the first link are net powered, others battery or wallwart) Give me a holler if you see something you like but can't figure out the text...
http://www.clasohlson.se/WAG.asp?cp=Eq0q179q918&ic=N&sw=9045
http://www.teknikmagasinet.se/shop/db.pl?template_file=db_product.html&ProductID=390399
Not projection, but pretty cool anyway
http://www.teknikmagasinet.se/shop/db.pl?template_file=db_product.html&ProductID=390045
#189440 - 14/11/2003 08:11 Re: Projection Clock [Re: ineedcolor]
ithoughti
Loc: Boston, MA USA
this one is pretty cool, not a box at all. From the UK
same one as above much better website
oohh, a handheld one too.
yet another
Edited by ithoughti (14/11/2003 09:02)
//matt
#189441 - 14/11/2003 14:22 Re: Projection Clock [Re: ineedcolor]
Folsom
Loc: Atlanta
Old link, here is the cathode tube clock:
Link
#189442 - 14/11/2003 21:43 Re: Projection Clock [Re: Folsom]
You guys got me on the Cathode Clock. One now rests on my desk at work.
#189443 - 14/11/2003 21:56 Re: Projection Clock [Re: ineedcolor]
thrasher
sharperimage.com they have two or three to choose from.
040103958 60g
#189444 - 15/11/2003 07:47 Re: Projection Clock [Re: gbeer]
Greetings!
Personally, I like my numbers orange and jumpy. I purchased a satellite controlled nixie clock - great item!!!
#189445 - 15/11/2003 15:24 Re: Projection Clock [Re: pgrzelak]
For some reason, I managed to read the whole page without thinking "That's really geeky" -- until I came to
The setup menu and controls are accessed via magnetic reed switches at the top of the clock using an included rod magnet.
Now that is geek genius. I must ask Hugo if there's any room left in the Karma casing for a reed switch to enter geek mode...
#189446 - 15/11/2003 16:47 Re: Projection Clock [Re: peter]
It is actually quite clever. There are no external buttons or controls. The top is removable, but it is not recommended due to the voltage needed to drive the nixies. Thus a rather interesting / elegent solution - the reed switches. No buttons, but you just wave the included magnetic wand over the switch.
I would really like a Geek Mode for the Karma!!!
