#195796 - 03/01/2004 10:57 Killing The Player From Telnet?
Chuck
Is there a way to kill the player app while in a telnet session? Or is there a proper way to kill the player app while in a telnet session? If I use 'kill xx' (where 'xx' is one of the player PIDs) the player just restarts. I would like for it to stop completely and not restart.
Thanks,
-Chuck
#195797 - 03/01/2004 11:49 Re: Killing The Player From Telnet? [Re: Chuck]
I haven't tested it, but try ``kill -2 <pid>''. Also make sure you have a developer release installed.
#195798 - 03/01/2004 11:57 Re: Killing The Player From Telnet? [Re: wfaulk]
Or if you've got empegface or VNC & Hijack then you can navigate the menu to the Quit option. You'll need quit=1 under [menu] in config.ini for that option to appear.
#195799 - 03/01/2004 12:02 Re: Killing The Player From Telnet? [Re: wfaulk]
Chuck
Thanks very much Bitt! That did the trick.
#195800 - 03/01/2004 12:06 Re: Killing The Player From Telnet? [Re: Chuck]
Chuck
Thanks for the reply, but I'm playing around with the version 3 alpha releases and one of them doesn't load far enough to get to the 'Quit' option.
#195801 - 03/01/2004 12:16 Re: Killing The Player From Telnet? [Re: Chuck]
BTW, that's the equivalent of pressing Ctrl-C from the serial prompt.
