#203103 - 08/02/2004 16:34 Database Error
zaeno
Loc: California
Emplode is giving me a "download failed when checking database" error. I tried downgrading to 2.0 and i also tried rebuilding the database using the directions at http://www.riocar.org/modules.php?op=modload&name=FAQ&file=index&myfaq=yes&id_cat=8&faqent=220#220 but it did not help. What should I try next?
empeg-car bootstrap v1.02 20001106 ([email protected])/12/24.IP 1.0 for NET4.0tarting playerpl
empeg usb
If there is anyone present who wants to upgrade the flash, let them speak now,y.e support initialised 0089/88c1 (save to d0004e00).
! tunedb_d
empeg power-pic driver initial
LAC construct 0x405ae008
e000 v1.04 Linux-2.2
Copying kernel...car - 2.1490 Dec
Calling linux kernel...s of 4096K size
Uncompressing Linux..................................... done, booting the kerne-
Probing primary interface...
empeg
hdb: F
l.TS
Linux version 2.2.14-rmk5-np17-empeg54 (rob@tatu) (gcc version 2.95.3 20010315 (L2300AT, ATA DISK drive.
hdb: FUJITSU MHL23
release)) #48 Wed Dec 24 15:41:06 GMT 2003is 206f6972 'ri
ide0 at 0x000-0x007,0x038
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b
Dentry hash table entries: 2048 (order 2, 16k)heck:20k re
hdb:
Buffer cache hash table entries: 16384 (order 4, 64k) < hda5 hda6 > hda2 hda3 hda4000-0x007,0x038 on irq 6
Page cache hash table entries: 4096 (order 2, 16k)hdb4
RAMDIS
POSIX conformance testing by UNIFIX2048kB Cache, CHS=58140/16/63
Linux NET4.0 for Linux 2.2blocks [1 disk] into ram d
Based upon Swansea Universit
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UARTic partition read-o
Signature is 206f6972 'rio ' (1998060
Memory: 15024k/16M
empeg display initialised.reserved, 372k data, 4k in
empeg dsp audio initialised(Dag Brattliystem) readonly
empeg dsp mixer initialised
empeg dsp initialised
D
empeg audio-in initialised, CS4231A revision a0066e000sic partition read
empeg remote control/panel button initialised.mount /dev
empeg usb initialised, PDIUSBD12 id 1012y NET3.039
ircomm_tty: vir
empeg state support initialised 0089/88c1 (save to d0004e80).nformance testing by UNIFIXond music partition334
empeg RDS driver initialisedtitiofirst music partition r
empeg power-pic driver initialised (first boot)ockEntry) = 16ayerJITS
Remou
RAM disk driver initialized: 16 RAM disks of 4096K sizer Society NET3
hda: FUJITSU MHL2300AT, ATA DISK drive
Starting player6384 bh
hdb: FUJITSU MHL2300AT, ATA DISK drive (ehash 16384 bhash 16384)pp: 49:size
! memory_
IrDA (t
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/6305ae008
Prolux 4 empeg car - 2.1490
Lin
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
V
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
allocating_buffer_pool.cpp: 49:sizeof(BufferEntry) = 32
allocating_buffer_pool.cpp: 50:sizeof(BlockEntry) = 16
player.cpp : 569:empeg-car 3.00-alpha5 2003/12/24.
! memory_stream.cpp : 42:MemoryStream failed to allocate memory.
! tunedb_disk.cpp : 878:Failed to build database. Bad. 0xc007000e
Prolux 4 empeg car - 2.1490 Dec 24 2003
Vcb: 0x4066e000
#203104 - 08/02/2004 17:31 Re: Database Error [Re: zaeno]
Daria
Do you have a ReserveCache set in config.ini?
#203105 - 08/02/2004 21:44 Re: Database Error [Re: zaeno]
Loc: Los Angeles, CA
seems as if you're still on a5. downgrade to a3 or v2final.
#203106 - 09/02/2004 02:16 Re: Database Error [Re: image]
zaeno
Loc: California
Can i check config.ini without being able to connect to the player? Also, I am still having the problem with 2.0 i just happened to print the boot log thing after switching back to 3.0a5
#203107 - 09/02/2004 02:33 Re: Database Error [Re: zaeno]
Daria
If you can install Hijack you should be able to ftp in and fetch the file.
#203108 - 09/02/2004 08:06 Re: Database Error [Re: Daria]
zaeno
Loc: California
Logo Editor is giving me error 53 when i try to instal hijack
#203109 - 09/02/2004 10:18 Re: Database Error [Re: zaeno]
RobotCaleb
mmm.. if i recall correctly, i think 53 is 'file not found'
perhaps you mistyped a location?
#203110 - 09/02/2004 11:35 Re: Database Error [Re: zaeno]
If you get error 53 when you run logo editor, it means you have not installed it correctly. Make sure to unzip everything, not just the main EXE.
Really, though, my main advice to you would be to just skip the alpha software that you're running and go back to 2.0 final. You'll have much less trouble with that and it will "just work".
#203111 - 09/02/2004 17:34 Re: Database Error [Re: tfabris]
zaeno
Loc: California
I am running 2.0 and the database problem wont go away. Emplode still can not connect. I got hijack installed and i can connect with ftp...but what should i do?
